zeyuanfu Splendid Jun 19, 2014 4,919 0 24,960 Jul 23, 2014 #2 Downham45 : The correct way to Format a drive Go to My Computer, right-click the drive you want to format and select Format. That's a low-level format. Hope I helped! Upvote 0 Downvote
DeadRam Distinguished Jun 14, 2007 557 0 19,160 Jul 23, 2014 #3 I don't think a manual low level format is safe. Are you trying to wipe a HD on a PC being donated? Use Dariks Boot & Nuke. http://www.dban.org/ Upvote 0 Downvote
ex_bubblehead Titan Moderator Aug 24, 2012 16,249 1,518 87,240 Jul 23, 2014 #4 A true low level format hasn't been possible outside the factory since the MFM/RLL days. Upvote 1 Downvote
zeyuanfu Splendid Jun 19, 2014 4,919 0 24,960 Jul 24, 2014 #5 A format from My Computer IS a low-level format... Upvote 0 Downvote
ex_bubblehead Titan Moderator Aug 24, 2012 16,249 1,518 87,240 Jul 24, 2014 #6 zeyuanfu : A format from My Computer IS a low-level format... No, it isn't. http://en.wikipedia.org/wiki/Disk_formatting Upvote 0 Downvote
D Downham45 Reputable Jun 7, 2014 2 0 4,510 Jul 25, 2014 #7 Thank you for the advice, the reason i asked because as is shown there are a lot of fore's and against. Upvote 0 Downvote
