How does all the x16/x8/x16/x8 etc work in regards motherboard slots, graphics cards and PCI lanes
spikeysonic
189
Can Someone explain how these PCI slots work and what is meant by stuff like this in regards mother board PCI slots and graphic cards (other than the physical slots I can see) vs PCI lanes
ie how does this work?
Expansion Slots
4 x PCIe 3.0 x16 (supports x16/x8/x16/x8*), 1 x PCIe 2.0 x4, 1 x PCIe 2.0 x1
vs
7 x PCIe 3.0/2.0 x16 (single x16 or dual x16/x16 or triple x16/x16/x16 or quad x16/x16/x16/x16 or seven x16/x8/x8/x8/x8/x8/x8)
Trying to "in a nutshell" this answer.
There are CPU PCIe lanes + chipset PCIe lanes. Storage, USB etc will all use some of the available lanes.
For example, an i9-9900K has a maximum 16 PCIe lanes.
https://ark.intel.com/products/186605/Intel-Core-i9-9900K-Processor-16M-Cache-up-to-5-00-GHz-
The chipset, Z390 adds 24 PCIe lanes.
https://ark.intel.com/products/133293/Intel-Z390-Chipset
For a total of 40. So, even before you factor in storage, USB etc, you can see there's no way a Z390 board could offer 3x x16 slots (=48 lanes), as it's just not available. Add an M.2 x4 slot or two (= x8 lanes used), there's only 32 left. In theory, you could still have dual x16 slots.... but some of those lanes are needed elsewhere. Meaning the max you will see is a single x16, or dual x8 bandwidth.
Vs an HEDT chip, like an i9-9980XE has 44 PCIe lanes:
https://ark.intel.com/products/189126/Intel-Core-i9-9980XE-Extreme-Edition-Processor-24-75M-Cache-up-to-4-50-GHz-
And the corresponding chipset bring another 24.
So, with that chip, you could theoretically have 3x full x16 slots, assuming the remaining 16 lanes are sufficient for elsewhere.
Those '*' will direct to further info on a spec page, which typically link to the CPU installed.
I don't know what boards you're comparing here specifically.
in the examples.
1.
4 PCIe slots, physically & electrically wired to be x16. With one slot populated, you can have x16 bandwidth (if required, for a GPU, for example).
If you populate the second corresponding slot, then both with run at x8 bandwidth/speeds (for SLI/Crossfire, etc).
2.
Based on the spec listed, this example could support 4x full x16 slots, and have provide maximum bandwidth to each (x16), or one slot at the full x16, and 6 others at x8.
Working that back though, you'd need 4 x16, or 1x 16 + (6x8) = 64 lanes..... and that's before anything else, likely storage.
As for CPU lanes vs Chipset, refer:
https://www.youtube.com/watch?v=JVihgHoy8Sg
Its part of the go with 19- 7900x i9-9900x or amd 2050 / or 1950x argument.
with the I9s there is the possibility of a asus sage mother board... this had 7 pci physical slots, but for some dumb reason lacks mid board usb 2 for fittign a liqiuid cooler according to PCSpecialist
ASUS® WS X299 SAGE
https://www.asus.com/us/Motherboards/WS-X299-SAGE/
Intel LGA 2066 CEB motherboard with quad-strength graphics supports, DDR4 4133MHz, dual M.2 & U.2, USB 3.1 Gen 2 connectors, and ASUS Control Centre
• 4-Way PCI-E Gen3 x16 link supporting NVidia GeForce SLI® and AMD CrossFireX™ on demand.
• Ultra-efficient VRM heatsink: Metal fin array connected to large surface area via a heatpipe tames X299 thermals to enable unthrottled performance.
• 5-Way Optimisation: One-click, system-wide tuning, delivers optimised overclocking and intelligent cooling for a diverse range of workloads.
• Industry-leading cooling options: Comprehensive controls for fans and water pumps, via Fan Xpert 4 software or the acclaimed ASUS UEFI
• ASUS Control Centre: A software utility that provides convenient, secure and cost-saving centralized IT management for small and medium businesses.
• Next-gen transfer speeds: Up to 32Gbps dual M.2 and U.2, plus up to 10Gbps USB 3.1 Gen 2 Type-A and Type-C front connector
Detailed Specification
RAM Slots
8 x DIMM, max. 128GB, DDR4 2666MHz
Expansion Slots
SATA Ports
8 x SATA 6Gb/s ports, 2 x M.2 Socket 3
USB Ports
1 x USB 3.1 Type-C port, 10 x USB 3.1 ports (7 at back panel, 3 mid-board), 4 x USB 2.0 ports (4 at back panel)
Networking
1 x Intel® I210-AT Gigabit LAN, 1 x Intel® I219-LM
Audio
Realtek® ALC S1220A 7.1-Channel High Definition Audio
with the AMD there seems to be a poorer choice
... there wont be a room but open up the choice of motherboards here
https://www.pcspecialist.co.uk/computers/amd-x399-pc/
