C computernewbie Distinguished Jan 13, 2009 576 0 18,980 Oct 21, 2009 #1 I dunno how the connection cable looks like, not the power cable, the other one that connects to the MB, pictures from google would be awesome, does the cable come with the optical drive? Or MB, cant find it...
hunter315 Champion May 12, 2009 10,651 3 51,960 Oct 21, 2009 #2 Generally it comes with the motherboard. Did you plug in a 4 pin molex power connector, if so you need to use an IDE cable http://images.google.com/imgres?imgurl=http://www.midtowncomputers.com/images/ATA133%2520Round%2520IDE%2520Cable.jpg&imgrefurl=http://www.midtowncomputers.com/cables.html&usg=__G67U9-OfWXIpq7QR2IfgqZp1UXI=&h=386&w=500&sz=9&hl=en&start=3&sig2=u3-Z5F95IVGdGhdaVqf1EA&tbnid=CO-lqfqm1PiCGM:&tbnh=100&tbnw=130&prev=/images%3Fq%3Dide%26gbv%3D2%26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US😱fficial&ei=Z4veSqaJN5TJlQf_m8Q3 If you plugged in a small black sata power connector you need to use a sata cable http://www.pcstats.com/articleimages/200708/LGGSAH62N_sata2.jpg sorry the IDE cable link broke, stupid BB codes
gkay09 Splendid Jul 28, 2008 8,861 0 31,960 Oct 21, 2009 #3 ^ There are 2 types of cables that are used to connect to the optical drive. 1. IDE - Which is a thick one - http://lagwar.com/home/wp-content/uploads/IDE_cable2.jpg But you get rounded ones too... http://www.personal.psu.edu/jea169/blogs/engl202c/IDE%20Cable%202.jpg 2. SATA - Thinner cables http://www.atechfabrication.com/images/htpc/products/SATA_Cable_data.jpg\ So first you have to check the socket type of the optical drive to know which cables can be used. If it looks like this, it would be a SATA drive - http://www.pcstats.com/articleimages/200708/LGGSAH62N_sata2.jpg This is an IDE drive... http://www.rhyshaden.com/images/dvd_ide.jpg
C computernewbie Distinguished Jan 13, 2009 576 0 18,980 Oct 21, 2009 #5 o sata works for both optical drive and hard drive? haha 😛. My MB came with an IDE and a couple SATA cables
hunter315 Champion May 12, 2009 10,651 3 51,960 Oct 21, 2009 #6 Both hard drives and optical drives use to be IDE, they are now switching over to SATA as its easier to fit onto the board and manage in the case.
C computernewbie Distinguished Jan 13, 2009 576 0 18,980 Oct 21, 2009 #7 thanks, i though they used different cables, makes my life easier. Off-topic, what does the USB 2.0 connect to, MB im guessing, (never openedup mine yet lol)
hunter315 Champion May 12, 2009 10,651 3 51,960 Oct 21, 2009 #8 Are you talking about the ones from the front panel of the case? Your motherboard manual will have a picture showing where to plug it in.
