Question How does case rgb strips work? Do any rgb strips work in the Eclipse P350x case?
FluffyFlounder
123
7
4,595
I will build a pc probably in about 2-3 weeks, and I am planning to get the Phanteks Eclipse P350x, and I am going for the rgb look with the ram and case. I know that the case has two verticle things on one side, and on the bottom horizontal side. I have some questions. 1: Does the case come with an rgb led strip? 2: If not, where can I buy one that works with the p350x? 3: How would I connect/install the rgb strip? Would it connect to the motherboard or somewhere on the case? Thanks in advance.
