How does my build look for FPS Gaming?
ThunderstruK
41
Case: NZXT Phantom Full Tower - £104
Motherboard: Gigabyte GA-Z68XP-UD3P Z68 - £120
Processor: Intel Core i5 2500K - £153
Graphics Card: Sapphire Radeon HD 7970 3gb - £335
PSU: Corsair AX 850W - £142
HDD: WD RE4 1TB - £93
SSD: OCZ Vertex 4 128gb - £100
RAM: Corsair Vengeance 8GB - £44
Optical Drive: LiteOn iHAS124 - £15
Wi-Fi Card: D-Link Xtreme - £45
Price: £1151
Gaming Monitor: BenQ XL2420T - £260
General Monitor: Dell UltraSharp U2410 - £290
Price: £550
Total: £1701
This is my first time ever building a PC and I wanted to get confirmation that everything will work well together. I will be using this computer for primarily gaming, mainly on FPS's like BF3 and up coming titles such as Crysis 3 and Medal of Honor: Warfighter. Do you guys think that this PC would be able to BF3 on the highest settings and still be able to reach above 60 FPS to take advantage of the 120hz monitor? My budget is round about the £1700-1900 mark so if you would like to recommend other parts that you think would increase my FPS within First person Shooters then it would be greatly appreciated.
Cheers.
you really don't need that large of a PSU:
Corsair TX 650W V2 £69.55
if you KNOW you are going to Xfire later than:
Corsair TX 750W V2 £83.19
first-
1-go with a cheap monitor for general work,a 19-20" display will do fine.get quality 1080p for multimedia and gaming stuff.the benq monitor you selected is great.
here's my suggestion for you-
samsung dvd drive-
http://www.scan.co.uk/products/samsung-sh-d163c-black-48x-cd-rom-16x-dvd-rom-sata-oem
phantom full tower-
http://www.scan.co.uk/products/nzxt-phantom-enthusiast-black-full-tower-performance-gaming-case-with-usb-30-w-o-psu
hyper 212 evo-
http://www.scan.co.uk/products/coolermaster-hyper-212-evo-4-heat-pipes-direct-contact-with-120mm-quiet-fan-lga775-1155-1156-1366-am
nzxt 200mm fan>>>> put it on the top of your phantom-
http://www.scan.co.uk/products/200mm-nzxt-11-blade-rifle-bearing-silent-fan-700rpm-fan-with-blue-led-and-braided-cable
3570k-
http://www.scan.co.uk/products/29-4intel-core-i5-3570k-s-1155-ivy-bridge-quad-core-34ghz-5-gt-s-dmi-650mhz-gpu-6mb-smart-cache-34x-
windforce x3 gtx 670-
http://www.scan.co.uk/products/2gb-gigabyte-gtx-670-windforce-3x-28nm-pcie-30-(x16)-6008mhz-gddr5-gpu-980mhz-boost-1058mhz-cores-13
1tb 7200rpm-
http://www.scan.co.uk/products/1tb-hitachi-0a39289-ultrastar-a7k2000-enterprise-24x7-7200rpm-3gb-s-32mb-cache
m4 256gb-
http://www.scan.co.uk/products/256gb-crucial-m4-slim-25-ssd-sata-iii-6gb-s-mlc-flash-read-500mb-s-write-260mb-s-50000-iops-new-7mm
low profile 1600mhz ram-
http://www.scan.co.uk/products/8gb-(2x4gb)-corsair-ddr3-vengeance-jet-black-lp-pc3-12800-(1600)-non-ecc-cas-9-9-9-24-xmp-15v
z77x-UD5H-
http://www.scan.co.uk/products/gigabyte-ga-z77x-ud5h-intel-z77-s-1155-ddr3-pcie-30-(x16)-d-sub-(vga)-displayport-dvi-d-hdmi-atx
TX750w V2-
http://www.scan.co.uk/products/750w-psu-corsair-enthusiast-series-cmpsu-750txv2-85-eff-80-plus-bronze-sli-crossfire-eps12v-quiet-fa
total: £1189.06
this rig will SLi,overclock,run almost every game maxed out and a lot more.
Thanks for the reply guys. Hellfire, is the extra fan for the case and the CPU really necessary? I was watching a review on the i5 3570K and the guy said that if you aren't going to overclock it then stock fan would be fine. I have no idea how to overclock and I don't really intend to, unless I really have too. Do you still think the extra fan and CPU fan is a must? Cheers.
first,overclocking is 100% safe,performance boost if done properly.there are a bunch of guides on internet.3570k has a lot of overclocking potential and it's worth overclocking.i would suggest give it a try.
or you can ask any of your friend who knows how to do these things.
if not then you should get a non "k" cpu and a cheaper h77 motherboard.
Stick with the K processor and Z77 mobo incase you do want to OC later. The stock HSF is fine for stock settings. Just get an aftermarket HSF later if you do decide to OC.
The case has a lot to do with personal preference, so pick one you like and someone here can tell you if there is anything majorly wrong with it.
gigabyte windforce x3 is one of the best gx 670 out there.
they are optimized to overclock.you can run BF3 with stock clocks but you can always boost your performance with some overclocking.
Ahh okay, thanks for the information on the GPU and the PSU. I had a quick read of the article on the asus GTX 670 and they seem to rate it highly. And it's for £20 more.
Btw, do you know if they do the PSU you are recommending in a modular form? A buddy of mine told me that I should get a modular PSU.
When I was purchasing a PSU for my rig the guy at microcenter told me to get a non-modular one. That's why I ended up with an Antec HCG620W.
Simple as this, he always gets customers who lost their modular cables and need to come back and spend another $20 for them.
I'm perfectly pleased with my modular PSU, it helped with cable management, which helps with air flow. I would definitely pay a little more for modularity (for both form and function).
Okay guys, thanks for all the advice. This is what I've come up with the help of your suggestions, tell me what you think :)
http://www.ebuyer.com/240814-nzxt-phantom-black-full-tower-case-phan001bk
Motherboard: Gigabyte GA-Z77X-UD5H - £153
Processor: Intel Core i5 3570K - £168
Graphics Card: Asus 2GB GeForce GTX 670 DirectCU II - £346
PSU: Corsair TX750 (Modular) - £88
RAM: Corsair Vengeance 8gb (Low profile) - £44
Extra case fan: NZXT Blue LED fan - £12
Price: £1168
Gaming Monitor: Hazro HZ27WC 8 Bit - £383
General Monitor: AOC E2343F - £120
Price: £503
Total: £1671
http://www.scan.co.uk/products/intel-core-i5-3570k1155-ivy-bridge-quad-core-34ghz-5-gt-s-dmi-650mhz-gpu-6mb-smart-cache-34x-ratio-7
http://www.scan.co.uk/products/2gb-asus-gtx-670-directcu-ii-28nm-pcie-30-(x16)-6008mhz-gddr5-gpu-915mhz-boost-980mhz-cores-1344-2xd
http://www.dabs.com/products/corsair-750w-enthusiast-series-tx750-modular-power-supply-7LGL.html?utm_source=google&utm_medium=product+search&utm_content=Q200
http://www.ebuyer.com/226057-wd-wd1003fbyx-re4-1tb-sataii-7-2k-64mb-enterprise-hard-drive-wd1003fbyx?utm_source=google&utm_medium=products&gclid=CP6TkZnw77ACFUYntAodA1X2wg
http://www.amazon.co.uk/dp/B007R1FH3K/ref=asc_df_B007R1FH3K8506301?smid=A3P5ROKL5A1OLE&tag=hydra0b-21&linkCode=asn&creative=22206&creativeASIN=B007R1FH3K&hvpos=1o2&hvexid=&hvnetw=g&hvrand=2126708363263594811&hvpone=&hvptwo=&hvqmt=
http://www.scan.co.uk/products/27-hazro-hz27wc-led-ips-pro-glass-version-8bit-dvi-2560x1440-420cd-m2-10001-6ms-speakers-pc-mac
http://www.currys.co.uk/gbuk/aoc-e2343f-23-led-backlit-monitor-07677510-pdt.html?srcid=198&cmpid=ppc~gg~UFC-Monitor~07677510~LT&mctag=gg_goog_7904_&gclid=CJmopcDV9bACFVQqfAodNkoLMw
Here are the links :)
