How does my first build look? Is everything compatible and reasonable for a gaming setup?
colson12
12
CAS: Corsair Carbide Series Spec-01 w/ USB 3.0, Side Panel Window
CD: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive
CPU: Intel® Core™ i5-4690K 3.5 GHz 6MB Intel Smart Cache LGA1150
CS_FAN: Default case fans
FAN: Intel Certified CPU Fan & Heatsink
FLASHMEDIA: None
HDD: 1TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD (Single Drive)
HDD2: None
IUSB: Internal USB 3.0 4-Port Hub
MEMORY: 8GB (4GBx2) DDR3/1600MHz Dual Channel Memory (G.SKILL Ripjaws X)
MOTHERBOARD: ASUS Z97-K ATX w/ Intel GbLAN, 2 PCIe x16, 2 PCIe x1, 2 PCI, 1 x M.2, 6x SATA 6Gb/s
NETWORK: Onboard Gigabit LAN Network
OS: Windows 10 Home (64-bit Edition)
POWERSUPPLY: 600 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO: NVIDIA GeForce GTX 970 4GB GDDR5 PCIe 3.0 x16 (Maxwell) (Single Card)
I would recommend the 390 over the 970. You should consider going with a skylake build. What PSU is that?
I could put together a build on pcpartpicker.com for you.
why a 390?
i would appreciate a reference build on pc part picker
what is your budget? do you mind filling out rebates? do you live in the US?
I want to stay around $1000-$1100, no problem filling out rebates, live in US
I want it to be $1000-$1100 before rebates
So this will be able to handle high framerates and everything else associated with gaming nowadays?
why did you remove a cpu cooler, would it not be needed?
if i did want to change the case, how many internal bays of each size would i need? and what other specifications would i need to follow?
Man, you are awesome. This helped so much and I feel confident going forward from here
