Hello, I am somewhat confused about how power supplies work. I'm right in thinking that a "500W PSU" can give a maximum amount of 500 watts to a component, and gives the others the appropriate amount? or does the 500W mean that if you add up the amount that each part of the pc is using and it reaches 500 or less, then a 500W power supply is ok for the system?
I am thinking of getting the amd phenom ii x4 965 Black Edition and overclocking it, although this is my first build.
If anyone can help with my question that would be great
Thanks
Thanks
