[SOLVED] How does ryzen 3600x fps do in dota 2 without graphics card on high to ultra settings? 16gb ram
May 16, 2020
5
Just wondering what's the fps of dota 2 in high to ultra settings with the following specs;
Ryzen 3600x
No graphics card
16gb ram
Planning to build without graphics card first and gpu to follow.
Will it not even reach 30fps on average?
You won't get a single frame, it isn't possible to have anything come up on display with this processor and no card. If you need to go with a CPU that has integrated graphics go with the Ryzen 5 3400G, it will be plenty enough for Dota 2 giving you around 60 FPS on average on max settings.
Ryzen 3600x
No graphics card
16gb ram
Unfortunately that specific processor requires a discrete GPU. There are no integrated graphics with it.
