A amol2706 Reputable Jan 22, 2016 2 0 4,510 Jan 22, 2016 #1 I cannot find network drivers for my sony vaio vpceh25en laptop since i have installed Win 7 Pro 32 bit. Can i use a mini usb wifi adapter to access internet. How does it works.
Solution logainofhades Jan 22, 2016 I may have found your network drivers. http://www.sony.co.in/support/download/417681 The USB adapter just plugs into a USB port, install drivers, and it should work just the same as your installed wireless.
logainofhades Titan Moderator Apr 27, 2009 39,370 4,633 143,290 Jan 22, 2016 Solution #2 I may have found your network drivers. http://www.sony.co.in/support/download/417681 The USB adapter just plugs into a USB port, install drivers, and it should work just the same as your installed wireless. Upvote 0 Downvote Solution
