[SOLVED] How fps will I get on fortnite
Feb 14, 2020
13
I am going buy Intel i3 9100f and GTX 1650 of 4gb graphic card and 12 Gb ddr4 2400mhz ram how much fps will I get on fortnite
GeForce GTX 1650 -- Intel Core i3-9100F
1080p Epic Preset
@ Epic 55+ fps
This is a game that is designed to work across a wide variety of hardware, that was the main design focus and part of the reason it is widely popular over many of the other harder to run FPS games.
There are likely to be some trade-offs because there a number of relevant configuration options.
For example:
https://www.dexerto.com/fortnite/fortnite-how-to-get-higher-fps-reduce-lag-pc-ps4-xbox-one-471040
And I am curious about the 12 GB RAM configuration. That may not be an optimal configuration.
Is it 8 GB + 4 GB or maybe 3 x 4GB? What motherboard do you have.
Moving your post to PC Gaming category.
Fortnite players therein may have additional comments and suggestions.
Msi h310 and one 8gb 2400 and other 4gb 2400
This is the only RAM impact you will notice in that title.
Single Channel vs Dual channel.
As long as your in a dual-channel configuration the impact of how many chips you run is minimal, Fortnite is not memory intensive.
Means then I should go for 2x4gb 2400 mhz ram will this be fine
