Hi I was just wondering how high a temperature was too high for a AMD 965be while folding. I usually have my PC on for a few hours a day while I jump on and off browsing the web etc. I figured if its going to be on anyway might as well put it to good use in the Folding@Home project. If I set it to use 100% off the idle processes it runs about 59C. My question is that too hot and should I run it at 100% or lower the system tray app to run at 75% or something to lower temps.
Thanks
Thanks
