Hello everyone just completed my first build was wanting to know if these are normal Temps for my cpu and overall how things look. My specs are
**CPU** | [Intel Core i7-4790K 4.0ghz
**CPU Cooler** | [Cooler Master Seidon 120V 86.2 CFM Liquid CPU Cooler]
**Motherboard** | [ASRock Z97 EXTREME4 ATX LGA1150 Motherboard] asrock-motherboard-z97extreme4) |
**Memory** | [G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory]
**Storage** | [Samsung 850 EVO-Series 500GB 2.5" Solid State Drive
**Storage** | [Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive]
**Video Card** | [MSI GeForce GTX 970 4GB Twin Frozr V Video Card
**Case** | [NZXT Phantom 410 (White) ATX Mid Tower Case]
**Power Supply** | [EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply]
**Optical Drive** | [Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer]
**Operating System** | [Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)]
**Case Fan** | [Corsair Air Series SP120 Quiet Edition (2-Pack) 37.9 CFM 120mm.
My readings on bios after running for 25 minutes at an ambient temperature between 20-22 Celsius.
Cpu temp: 32 c
Mobo temp: 23c
Cpu fan 1: 1935 rpm
Cpu fan 2: 1888rpm
Cpu input voltage: +1.766v
Cpu v core: +1.056v
Cpu cache voltage +1.184v
system agent voltage : +0.824
Cpu analog io voltage: +1.008
cpu digital io voltage : +1.016.
Still newbie when it comes to builds so if you could break down what those readings mean it would be much appreciated. Also I'm planning on over clocking do you forsee any problems doing so?
Cpu temp: 32 c
Mobo temp: 23c
Cpu fan 1: 1935 rpm
Cpu fan 2: 1888rpm
Cpu v core: +1.056v
