How long can laptop keep working if battery is dead
abbarich
137
My battery died a few days ago so I've been using it plugged in since then. It was on 50% battery life but every day it drops 1%. Now it's 46%. Will the laptop keep working while plugged in even when it's dropped to 0%? Thanks.
What laptop? Someone might know. Some laptops can run without a battery, others need a functioning battery.
Thanks for the repies. Make and model is Lenovo ideapad 100. It s's about 4 -5 years old. I would remove the battery but unlike my last laptop it's not a battery you can slot in and out. It needs to be dismantled. Will it damage the laptop if I don't replace it? Thanks.
