S samanater456 Honorable Jan 29, 2014 22 0 10,510 Feb 4, 2014 #1 fan: http://www.pccasegear.com/index.php?main_page=product_info&cPath=9_510&products_id=23853 case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119256 motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128555
Solution tiny voices Feb 4, 2014 It is more than enough. All any computer needs to stay cool is a front intake, top exhaust, and rear exhaust. Anything else in not necessary.
S samanater456 Honorable Jan 29, 2014 22 0 10,510 Feb 4, 2014 #3 sweenytodd : 4 fans in total. ok would that be enough to cool everything in my computer? Upvote 0 Downvote
tiny voices Titan Sep 6, 2012 34,175 5 99,965 Feb 4, 2014 Solution #4 It is more than enough. All any computer needs to stay cool is a front intake, top exhaust, and rear exhaust. Anything else in not necessary. Upvote 0 Downvote Solution
S samanater456 Honorable Jan 29, 2014 22 0 10,510 Feb 4, 2014 #5 tiny voices : It is more than enough. All any computer needs to stay cool is a front intake, top exhaust, and rear exhaust. Anything else in not necessary. ok. thank you very much guys ! 😀 Upvote 0 Downvote
tiny voices Titan Sep 6, 2012 34,175 5 99,965 Feb 4, 2014 #6 Unless you have a crazy GPU setup, you cannot overclock on that board so your build will not even get hot. A front intake and a rear exhaust will be more than enough for your computer. Upvote 0 Downvote
S samanater456 Honorable Jan 29, 2014 22 0 10,510 Feb 4, 2014 #7 i was going to get a gtx 760 and an i5 3570k. and i wasn't looking to overclock. (as i never have before) Upvote 0 Downvote
tiny voices Titan Sep 6, 2012 34,175 5 99,965 Feb 4, 2014 #8 Your motherboard cannot overclock so don't wast money on that CPU. Get an i5 3470 or 3570. The 760 will be great. The only needing a front intake and rear exhaust stands as those components will not get very hot at all. Upvote 0 Downvote
S samanater456 Honorable Jan 29, 2014 22 0 10,510 Feb 4, 2014 #9 tiny voices : Your motherboard cannot overclock so don't wast money on that CPU. Get an i5 3470 or 3570. The 760 will be great. The only needing a front intake and rear exhaust stands as those components will not get very hot at all. is there much of a performance difference? Upvote 0 Downvote
tiny voices Titan Sep 6, 2012 34,175 5 99,965 Feb 4, 2014 #10 Between the CPUs, no there is no noticeable different at all. Upvote 0 Downvote
