[SOLVED] How many cooling fans can i put in with HP 198E motherboard?
KromeMY
I have been using 198E for a while and I have never put any extra fans. The only fan that I have been using all this time is a fan that is on the motherboard. Yes. I have been using just 1 fans in my cpu. I thought about getting more fans but I don't know how much fan can my motherboard support...
Any motherboard should have one header for the CPU fan and one for the System fan. You can install as many fans as you wish simply buying a fan splinter or hub but make sure that there is enough power for them
I currently using a 600w power supply.. does that work?
You need to find out how much power your components need. You can calculate it on your own or use a power supply calculator (there are lots of them on the net, I usually use this one https://outervision.com/power-supply-calculator )
And don't forget that if you're going to upgrade your PC in the future than it's better to have higher wattage
