R Rectifier Commendable Feb 22, 2016 90 0 1,630 Mar 11, 2016 #1 My mobo: https://www.asus.com/Motherboards/B150M-A/ Thanks
Solution JackNaylorPE Mar 11, 2016 Hit the specs tab on your link https://www.asus.com/Motherboards/B150M-A/specifications/ 1 x CPU Fan connector(s) (1 x 4 -pin) 2 x Chassis Fan connector(s) (2 x 4 -pin) Click to expand... You can use splitters but no more than 2 fans per header. or use one of these which is much neater and you can use up to 11 fans of PWM header.: http://www.newegg.com/Product/Product.aspx?Item=N82E16811984004
JackNaylorPE Titan BANNED Oct 30, 2004 32,252 14 99,960 Mar 11, 2016 Solution #2 Hit the specs tab on your link https://www.asus.com/Motherboards/B150M-A/specifications/ 1 x CPU Fan connector(s) (1 x 4 -pin) 2 x Chassis Fan connector(s) (2 x 4 -pin) Click to expand... You can use splitters but no more than 2 fans per header. or use one of these which is much neater and you can use up to 11 fans of PWM header.: http://www.newegg.com/Product/Product.aspx?Item=N82E16811984004 Upvote 0 Downvote Solution
T TJ Hooker Titan Ambassador Apr 15, 2014 11,632 1,770 72,390 Mar 11, 2016 #3 2 case fans + CPU fan. If you get a couple fan header splitters, you can run up to 4 case fans. Upvote 0 Downvote
