How Many Graphics Required ?
Aneesh@4GHz
806
I have a samsung 2233sw lcd monitor with 1920 X 1080 resolution :) , Is 512mb videoram enough for it :ange: , i like to buy a palit 9600gt 512mb gddr3 version,is it enough for gaming in it :hello: (Games like crysis ) am i able to play at full res with out AA and ASF :ange:
Videoram alone isn't the answer. I currently game on 1920x1080 with a 4870 512mb card, and am very happy with it (though I do miss my x2). Highspeed video ram combined with a good GPU is the answer for large resolutions. A 1gb GDDR2 9500gt for example, would be a waste, as the card can't even use the ram (its a marketting gimmick) but makes better use of 1gb on the DDR3 version.
Gaming without AA/AF will reduce your needs heartily, as those functions are resource hogs. You might get by with the 9600GT, but would probably be better served by at least an Nvidia 250 or ATI 4850.
Notice BSD, that he didn't mention details, just the resolution. If you want higher details running at that resolution, indeed, your should set your minimum sights at the 260 or 4870. In those cards, extra ram works well (though not essential without AA/AF or ultra high details).
Thanks for ur reply,
Well i think palit9600gt has 650mhz core and 900mhz memory,i think its good Wat abt ur opinion ?
I played crysis and protoype,cOD 4,COJ on my brothers laptop at maximum details and antialiasing,he has a MOBILITY RADEON HD4650 1GBDDR3, with 550mhz core & 667MHZ memory!So i had a look at this card!
