Hi, this is my first post, and i did read the rules and best practices, but still i want to apologize if im not posting in the right place for this question. And, i did some research on here regarding the various things i am trying to do, but through a mix of inexperience and lack of knowledge, i am unsure if i have the right answers, so i wanted to present my question from scratch.
Background: To get to my Windows 11 licensing question, i have to give some background explaining hardware for a new PC build, why i need it, and how i plan/hope to use it. Long story short, i have a work laptop that isnt performing well enough, so i am going to build a PC with the necessary capacity for the work i need to do. But, i am not going to spend as much as it takes to make a high-performance PC just for it to sit in my office and not be able to play games on it as well. So, i will be remoting into the PC i build from my office and using it to do the heavy lifting with which my work laptop struggles. I also have current PC that is mid-to-low end from which i will scavenge certain pieces.
Licensing: My work laptop has Windows 11 Pro, and my personal PC has Windows 11.
Plan: I intend to run a dual boot setup on my new PC build using separate SSDs. For the first SSD, i want to just move the one in my current computer over to the new build. For the second one, i want to clone my work laptop's 2230 SSD onto a 2280 SSD and use the 2280 SSD on the new pc build. My plan is to boot up the cloned work SSD in the mornings so i can remote into that drive from my office so that i can use the drastically better hardware i need, and then when i return home, i can boot up the personal SSD to play games.
Questions:
1. Can i move the SSD on my current personal computer over to the new build without obtaining a new license?
1a. If not, is it possible to transfer licenses to new hardware somehow so that it is no longer activated on old hardware and reactivated on new hardware?
2. Can i use a cloned SSD without obtaining a new license for the work SSD? (i assume not because that would be an infinite license glitch, but it doesnt hurt to ask)
3. If not, and i have to obtain a new license, would i still have the same Microsoft office programs as i do on my current work laptop or would i also have to obtain a new subscription for those as well?
4. Is there anything obvious im missing or an easier way to do this? At least as far as the licensing goes? (for instance, i have a clunker mini pc that i havent used in years but which works fine. So, could i move my current laptop ssd to the new pc build using a ssd adapter to make the 2230 fit into the 2280 slot and use the clunker just to remote into the new pc build that would have the current ssd?)
Thanks again yall!
Questions:
Thanks again yall!
