How many volts has intex 500 watts power supply
tokencode
847
I'm not sure you quite understand how power supplies work. Input voltage would normally be 110/220 AC and output would normally be 5V or 12V DC.... Wattage is a measure of power that is Volts * Ampheres. If you were to run a 110Watt lightbulb, it would draw 1 amp of power. All power supplies are consistent with their voltages so when you see a watt rating on a power supply, you are really talking about the current it can handle.
The label will tell you its rated output. Whether or not it can actually provide its rated output will depend on the quality of the PSU.
