How many watts above estimated power usage PSU should I get?
dyl47
212
I am getting a 600w corsair PSU, according to a calculator I should get a minimum 540w PSU. Will this be enough?
The build is i7 4790k w/ 760ti, 32gb ram, 3HDD's
PSUs are usually most efficient between 50%-60% load, so bear that in mind. As said, the Corsair CX/CS series is fine for the most part, but certainly not the best. I had a CX750M which developed a horrendous fan noise after just a few months. I've now switched to an XFX XXX Pro, which is far superior and cheaper.
Your CPU and GPU should pull around 258W when both are at full load. Obviously, you need to add a few extra watts for drives, fans, overclocking, etc. so on that basis, a good 600W PSU will do just fine. It's slightly overkill, but it gives you room for expansion.
If the PSU is a CX600, you should know that it only delivers 480W on the all-important +12V rail. That's 120W less than the stated power output.
