How much does room temp affect PC cooling?
ddemon
108
Hi,
I'm planning an i5 2500k build for gaming and multi media, with a view to overclocking and just for constant day to day use. I live in a reasonably hot climate +40C at times in summer and i have no home air con. How much will room temp affect my cooling needs?
There seems to be alot of different stuff written about fan configurations in cases these days and i'm just wondering if anyone here any personal experience that might help me in choosing a case?
So far i'm considering things like:
NZXT Phantom (for aesthetics as it will be in my living room next to the TV running as a gaming and media center)
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=7024943&body=MAIN
or
Cooler Master HAF932
EdpNo=4146085&CatId=1510http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4146085&CatId=1510
just as examples as i'm open for suggestions please
40c. is 104f. My synpathies.
The very best coolers in an open test bed will give you cpu temperatures of 27c over ambient. So you are starting at 67c.
Overclocking, you can expect 35c over ambient. Inside a case, it will be worse.
Here are some suggestions:
1) get the best aftermarket cpu cooler you can afford. Something like the prolimatech megahalems.
2) Plan on a noisier pc. Use higher output fans on the cpu cooler.
3) Get a case with high airflow. Two 120mm intake fans or two 120mm output fans would be a minimum. Replace the stock fans with higher output versions.
4) Abandon thoughts of a spiffy looking case. Get one that is functional. Something like the Antec 100, 200, or three hundred.
5) get a...
I hope his water table is close to the ground..geo you really think you can find water at 2 meters? Where your at it must be a swamp...my well is 220 feet deep at my house...I have seen water wells as deep as 984 feet as I am a water operator in the states..If you did get it a 2 meters...How are you gonna circulate it? Pumps, tubing, etc...equal big bucks....So, yeah neat idea if you got the money
I have seen whole housing development using geothermal wells......intially its crazy expensive yet it is very reliable and green...constant 68F all the time...they use a sistern and pump water down to like 80 feet through special lines that transfer heat from the incoming water then pump it back through a coil with a fan attached to your homes duct work
awesome!
so now how can i harness into this great idea... i have a pick and shovel, some garden hose, a couple of peddistal fans and maybe power it with an old mower engine ...lol
Kit for sure!
Giga Watts? ...nah your thinthing of the HyperWell Hydro 1.0 Pro
The X series Deluxe is the 350 hp petrol driven system ...lol
wow this is the worst off thread i've seen here yet ...lol
and i'm half to blame ...lol
Oh, no. You should see some of our really off the wall threads. Some of badge's posts come to mind.
whats the story with downclocking? ...is it standard these days or only on some models ,etc, etc?
