L LittleYo10 Distinguished Oct 14, 2013 277 0 18,790 Jul 9, 2015 #1 Hi, I wanted to know how much fps difference there is on 1440p monitors. Since I keep seeing things about amd drivers not being good and it's power consumption. Thank you.
Solution computertech82 Jul 9, 2015 http://www.tomshardware.com/charts/2015-vga-charts/09-Dirt3-2160p,3672.html 390 is basically a renamed 290. About 5-7fps faster than a 970. Not much difference. Boils down to cost.
okcnaline Splendid Nov 17, 2013 8,083 5 26,965 Jul 9, 2015 #2 I think Tom's had it around 7 FPS difference for 1080P. Upvote 0 Downvote
PCBuilderProbs Reputable Mar 24, 2015 780 0 5,360 Jul 9, 2015 #3 for 1440p most ppl say go 390/390x. The extra VRAM helps it surpass the 970 in 1440p/4k (but the 970 is a very close second indeed) Upvote 0 Downvote
computertech82 Distinguished Mar 26, 2006 1,362 0 19,860 Jul 9, 2015 Solution #4 http://www.tomshardware.com/charts/2015-vga-charts/09-Dirt3-2160p,3672.html 390 is basically a renamed 290. About 5-7fps faster than a 970. Not much difference. Boils down to cost. Upvote 0 Downvote Solution
