How much FPS will my computer get on BF4 ultra settings?
Lucas Iemini
156
14
Dont worry about it, you will be more tha capable to play it ultra settings 60+ FPS, consider using the EYEFINITY technology to get multiple monitors to enhace your experience :)
brotherhood2255
7
Thanks for the help!
Lucas Iemini
156
14
Glad to help ! :)
ewok93
Dignified
Seems like they've answered you already, but you'll definitely get 60+ on ultra.
And that's without Mantle, which may give you even better performance.
Personally, Eyefinity gives me a headache, and the black bars in the middle of the screen bother me, so it's something worth looking into, but it has drawbacks, and costs quite a bit. I find it's better and cheaper to get a higher resolution, larger single monitor, they've got widescreen monitors that give you the same effect with just one screen, like this one.
Similar threads
