How much power will i need for my build?
koreanmush77
Hey I am new to PC building and I would like to know how much power i need. I will list the components below
SanDisk SSD PLUS 120GB Solid State Drive
ASUS ROG STRIX B350-F GAMING AMD Ryzen AM4 DDR4 HDMI DisplayPort M.2 USB 3.1 ATX B350
Ballistix Sport LT 16GB Kit (8GBx2) DDR4 2400 MT/s
EVGA GeForce GTX 1060 SC GAMING, ACX 2.0 (Single Fan), 6GB GDDR5, DX12 OSD Support (PXOC), Only 6.8 Inches Graphics Card
WD Blue 1TB SATA 6 Gb/s 7200 RPM 64MB Cache 3.5 Inch Desktop Hard Drive
AMD Ryzen 5 1500X Processor with Wraith Spire Cooler
A quality 450W PSU would be fine. You system uses ~170W on a gaming load: https://www.techspot.com/review/1209-nvidia-geforce-gtx-1060/page8.html
Don't choose a power supply by brand, there is no such thing as quality brand as they all have good and bad units.
Also, that tom's PSU tier list is really horrible. I highly advise staying away from it as it is more misleading and incorrect than useful.
What is your budget for the PSU and where are you located.
600/700w be more than ample its good to have a buffer with psu if you wanna add to your build. Go with from bronze to gold range in psu"s dont skimp on price buy quality & buy the brands with great reviews use toms teir listing to gauge its quality range. The 1-2 teir is where to aim
My budget is under $170 and I usually order parts online.
