How much should I ask for a HP ZBook 17 G3 (X1X64UT#ABA)?
tristan256k
5
Looking to see how much I should ask for this Mobile Workstation. Thanks in advance!
Condition: Like-New in box, used for a week with no zero blemishes, bumps, scratches, etc...
Model: HP ZBook 17 G3 (X1X64UT#ABA)
*****SPECS FOLLOW*****
Operating System: Windows 7 Professional 64 w/ WIN10 Pro install media
Processor: Intel® Core™ i7-6700HQ with Intel® HD graphics 530 (2.60 GHz, up to 3.50 GHz with Intel Turbo Boost Technology, 2133 MHz, 6 MB L3 Cache, 4 cores)
Chipset: Mobile Intel® CM236
Memory: 1x16GB DDR4-2133 Non-ECC SDRAM, (4x total memory slots)
Internal Storage: 1TB SATA (7200 rpm)
Display: 17.3" diagonal FHD UWVA IPS anti-glare LED-backlit (1920 x 1080);
Discrete GFX: NVIDIA® Quadro® M1000M (2 GB dedicated GDDR5)
Expansion Slots: 1 SD UHS-II flash media; 1 smart card reader
Ports and Connectors Left side: 1 RJ-45; 2 USB 3.0; 1 USB 3.0 (charging)
Right side: 1 power connector; 2 Thunderbolt™ 3; 1 VGA; 1 HDMI 1.4; 3 USB 3.0; 1 stereo microphone-in/headphone-out combo 6
Networking LAN: Integrated Intel® I219-LM Gigabit Network Connection
WLAN: Intel® Dual Band Wireless-AC 8260 802.11 a/b/g/n/ac (2x2) Wi-Fi and Bluetooth® 4.0 combo;
Audio: Bang & Olufsen HD audio.
Input Device: HP Spill Resistant Keyboard (backlit with function key control); Image sensor touchpad with on/off button, two-way scroll, gestures, three pick buttons. Pointstick with
three additional pointstick buttons.
Power: 200 W Slim Smart AC adapter (external)
Battery: HP Long Life 6-cell 96 WHr Li-ion prismatic
TONS of built in security features geared toward mobile workstation
Dimensions: (W x D x H) 16.5 x 11 x 1.2 in (420 x 280 x 30 mm)
Weight: approx 6.62 lb
Warranty: Protected by HP Services, including a standard limited 3 years parts, 3 years labor, and 3 years onsite service (3/3/3) warranty. ADDITIONAL: 3 year Care Pack w/ accident protection.
Thanks again!
Thanks for the reply penguintech, I don't think I was expecting that high of a recommendation. I would be happy selling it for around $1400-1500... while your quote was higher, do your or anyone else think my price is fair?
Bignastyid, I appreciate your input but I am failing to see the direct comparison to the provided link and the device I posted as this is not a refurbished device but practically new in box. It also comes with a three year warranty with three years accident protection. With that said, I could see $1200-$1500. Would you agree that is a fair price?
