How much should I resell my custom PC for? Suggestions on where to sell?
Liam_83
Hello, I am from Canada, about to move away from home for university, I plan on buying a laptop, and since I rarely use my desktop I thought I should just sell it.
Here are the specs:
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
https://www.newegg.ca/Product/Product.aspx?Item=N82E16820233180
Corsair Carbide Series 200R Black Steel / Plastic Compact ATX Mid Tower Case
https://www.newegg.ca/Product/Product.aspx?Item=N82E16811139018
GIGABYTE GA-970A-UD3 AM3+ AMD 970 + SB950 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
https://www.newegg.ca/Product/Product.aspx?Item=N82E16813128519
ASUS Radeon HD 7850 DirectX 11 HD7850-DC2-2GD5-V2 2GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
https://www.newegg.ca/Product/Product.aspx?Item=N82E16814121651
CORSAIR CX Series CX600 600W 80 PLUS BRONZE Active PFC ATX12V & EPS12V Power Supply
https://www.newegg.ca/Product/Product.aspx?Item=N82E16817139028
AMD Phenom II X4 965 Black Edition Deneb Quad-Core 3.4 GHz Socket AM3 125W HDZ965FBGMBOX Processor
https://www.newegg.ca/Product/Product.aspx?Item=N82E16819103727
Seagate Desktop HDD ST1000DM003 1TB 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
https://www.newegg.ca/Product/Product.aspx?Item=N82E16822148840
ASUS 24X DVD Burner
https://www.newegg.ca/Product/Product.aspx?Item=N82E16827135204
Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan
https://www.newegg.ca/Product/Product.aspx?Item=N82E16835103099
I read somewhere 30% of the original value is a good resell price, but I think because the parts are fairly outdated that number will change.
Also, it comes with Windows of course.
Since I live in Canada, we generally sell things using kijiji, like a more professional craigslist. Is this good, or are there other places you recommend?
Thanks for all your help.
Latest posts
