[SOLVED] how much watt to power I3-9100F , RX570 GB
A good quality 450W would be fine. 550W if you wanted more headroom later.
How many PCIe connectors does your card in question require? If it only requires 1 and you're looking for more budget friendly:
Power Supply: Corsair CX (2017) 450 W 80+ Bronze Certified ATX Power Supply ($53.88 @ OutletPC)
Total: $53.88
If not - based on current prices if USD:
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply ($64.99 @ Amazon)
Total: $64.99
Power Supply: Cooler Master MWE Gold 550 W 80+ Gold Certified ATX Power Supply ($76.99 @ SuperBiiz)
Total: $76.99
Power Supply: SeaSonic FOCUS Gold 550 W 80+ Gold Certified Semi-modular...
Total: $53.88
Total: $64.99
Total: $76.99
Power Supply: SeaSonic FOCUS Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply ($84.99 @ B&H)
Total: $84.99
Reactions: KRizzYT
Total: $53.88
Total: $64.99
Total: $76.99
Total: $84.99
can MWE450 fit in my m-atx case?
Well there are no mATX PSUs.
mATX cases are usually just referring to the motherboard compatibility.
Unfortunately the spec sheet on your case is not very detailed.
However like nearly all mATX cases, I would suspect it is made to fit a standard ATX PSU.
Unlikely it only takes small form factor, and it doesn't mention that at all in the specs.
Do you have a PSU currently in place?
Reactions: KRizzYT
I did burn a 520W PSU with RX570. I did buy the Kolink 700W Core KL-C700. Runs fine with the RX580 too and have many pci-e power connectors.
That's because the 520W you had was probably poorer quality or an old platform without adequate protections. Or that the 12V rail wasn't adequate for the GPU. Not because of the wattage of the PSU.
As the Kolink you have linked is also poor quality and would hold the same risk should it blow unfortunately.
The RX570 absolutely does not need more than 500W in most systems :)
See point 1 here: https://forums.tomshardware.com/thr...when-selecting-parts-for-a-custom-pc.3510178/
Latest posts
