Zectorr Distinguished Apr 18, 2015 180 2 18,695 Jun 13, 2015 #1 Before i buy a ASUS R9 280X 3Gb GPU i want to know if my current Antec 500W 80plus Bronze Earthwats Psu would be enough thanks
Solution learningbitbybit Jun 13, 2015 It would be cutting it too close. You might be able to do some light surfing but anything that requires more CPU usage then it will crash. Consider getting this, it will be enough for overclocking as well: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817151095
learningbitbybit Reputable Jan 15, 2015 994 0 5,660 Jun 13, 2015 Solution #2 It would be cutting it too close. You might be able to do some light surfing but anything that requires more CPU usage then it will crash. Consider getting this, it will be enough for overclocking as well: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817151095 Upvote 0 Downvote Solution
G garneroutlaw Reputable Apr 23, 2015 93 0 4,660 Jun 14, 2015 #3 A 620 bronze for 90 bucks? You can do better than that. You should be able to get any 600w bronze for under 60. Upvote 0 Downvote
