How quiet is Hyper 212 Evo CPU cooler supposed to be?
romethaug28
112
Hello,
I recently got a new CPU cooler( Hyper 212 EVO) to get my PC to be quieter.
I notice it when i am wearing my headphones. Anyone has experience with this CPU fan.
The tempretures are 35 C when being on internet and 50 C if playing games.
Is it supposed to be like that. Or how quiet is your CPU fan.
There is no way to change the speed also, i think. Not atleast with Fanspeed.
All advice is welcomed!
Thank you!
I owned the 212 when I had my X4 965, while it's not the quietest cooler out there compared to the stock cooler running at 100% the difference in noise and temps was quite drastic.
Your temperatures seem nominal.
The hyper212 is not one of the best 120mm coolers out there.
Here is a review of the $35 scythe kotetsu. At the end, there is a table of noise vs. cooling which includes the hyper212.
http://www.silentpcreview.com/article1391-page6.html
If you are inclined to change out the cooler, I can recommend the kotetsu from personal use.
Your motherboard should have some sort of fan control mechanism in the bios. Look for that.
can i just change the fan and not the hole cooler?
Thank you!
Yes, you can.
Noise comes primarily from the rpm that the fan is running at.
Noctua makes very nice fans.
They also come with some low noise adapters. Check that you need a 4 pin fan, usual for a cpu cooler.
Here is the noctua NF-F12 fan.
https://www.amazon.com/Noctua-NF-F12-PWM-Cooling-Fan/dp/B00650P2ZC
You can alternatively buy the low noise adapters for less:
https://www.amazon.com/Noctua-NA-SRC7-Accessory-Low-Noise-Adaptors/dp/B00KG3KP1U
