G
Guest
Guest
hi everybody !
please help me because my Micro-SD-HC card 8gb Class 4 has a write protection. and i can't remove the folders and i can't format.
this sd card come on of a smartphone HTC Legend, if you can understand the problem ?
i don't have a solution and i need you for find this solution.
i tried
- i used cmd command for formated but no result
- i used softwares for format sd card but no result
- i changed the autorisation in regedit command but no result
- i talked with her but no result. i just kidding
or not
- i launched a boot-cd but no result
please, i going crazy with this problem. i not understand what happend. help me please.
thank you very much for you answer.
i tried
or not
