[SOLVED] How should I upgrade my HP Compaq Pro 6300 Microtower
kerma16
I have an old Hp 6300 microtower with an amd R7 250 gpu.
I wanted to upgrade my gpu realized that I'd have to upgrade my PSU and if I wanted to upgrade my PSU I'd first have to upgrade my Motherboard.
So first off what mother board and PSU will be compatible with my case or will I have to buy a new one?
Also am I just better off buying a new system or is there any point in upgrading this one?
Also my current system
Intel Core i5-3470
8 GB ram
2 500 GB hard disk
Amd R7 250
What about this guide will it work?
That seems to be a solid resource, but I would call moddiy and see if they have a plug and play solution for this. Even I would be a bit nervous about swapping wires around because one wrong move and you'll probably toast the motherboard, power supply, or everything connected. 😱 And this is from someone who regularly pulls pwm pins from fan connectors so I've pretty much messed around with swapping pins before.
Yeah, about time for a whole new system.
Motherboard, CPU, GPU, RAM
And then of course a new PSU to run the GPU.
A new case to put it all in.
Only viable holdovers are possibly hard drives. And then only as secondary drives.
You want a good SSD in there...😉
Thing is my all my components minus the gpu are enough I sometimes play games that aren't too graphic intensive Age of empires, civ and total war games and some Photoshop.
Also I'm on a tight budget so is it possible to upgrade my current one?
Well, if it currently works, then no real need of a major change.
If the current motherboard is not ATX spec, then to take a new PSU you'd need a new motherboard, that matches your existing CPU and RAM.
Also, if it is not ATX, then a new motherboard won't work with the HP case.
What PSU is in it now?
The one that came with the system.
Luckily you have the tower version of that. I haven't been able to find anything conclusive as of yet, but it looks like a power supply upgrade should be fairly easy using any standard power supply and a power supply adapter from moddiy.com. Once you've upgraded the power supply, you should be able to use a newer gpu. You can also upgrade to an i7-3770k to max it out.
So I can just get a new PUS and a 24 pin to 6 pin adapter?
Yep, but the adapter is key--I would call moddiy and MAKE SURE it will 100% work with your motherboard before going out and buying everything. Otherwise you are stuck with what power you have.
Okay, I'll try that.
Thanks man.
