Hello friends, i am looking to add an antenna to this network card (Atheros Ar5b22) for enhancing wireless range. It can only detect my router if my PC is a few feet away. The problem is that this device doesn't have a port to connect any antenna.
However, i do recognize two CH0 and CH1 ports on the chip. Unfortunately, they are not connected to any external terminal.
I found this product on aliexpress which i think will be able to connect to these ports. I am not sure though.
Please suggest what can i do. If it get this product, will it connect to my card and be able to use internet properly. I use this PC for gaming, just casual gaming though. I cannot connect an ethernet. I also don't wanna spend bucks on a new card since i think i can upgrade this with help of this generous forum.
Thanks!
Here is a full picture
Thanks!
