Hello,
You may need to update or re-install your Asus Smart Gesture touchpad again.
The update/driver is available at the Asus Support site under TouchPad.
If you are not sure how to get and install this driver see the following instructions;
Note: For safety create a System Restore Point first at
Control Panel > All Control Panel Items > Recovery > Configure System Restore > Create
• Uninstall your current elan touchpad driver.
• Restart your PC.
• Go to your local Asus website at ASUS
• Click on Support.
• Enter the Model Name of your laptop, but if you are unable to find your model name, it can be found at
Control Panel > System and Security > Administrative Tools > System Information > System Model
• Choose your OS.
• Click on...
