how to adjust volume on VE247 monitor
lgs
Volume is at 0. Can't adjust. Pushing up button on monitor, but nothing happens. Can't get to volume through menu either. Thanks.
http://www.manualslib.com/manual/210862/Asus-Ve247h.html?page=8#manual
http://www.manualslib.com/manual/210862/Asus-Ve247h.html?page=17#manual
Would assume that you press the button for volume adjustment and then press the up/down buttons to adjust it. If you can't access that function, make sure the audio cables are properly connected and that any drivers/software it came with are up to date. Might also want to check the system volume on your computer itself to make sure it wasn't turned to mute.
