I attached a NA-SFMA1 adaptor to a Noctua NF-A12x25, but I don't understand what screws you're supposed to use to mount it to a case.
It looks like this right now: http://www.enostech.com/wp-content/uploads/2018/06/20180605_160650-Copy-1080x675.jpg
How do you physically attach it to the front of the case? There are no screws provided with the NA-SFMA1. The NF-A12x25 came with 4 small screws, but where exactly would they fit in the pic above? The fan mounting holes are occupied by the anti-vibration stick thingies that are sticking up. Am I missing something? I'd appreciate any help!
For reference, I'm using a Meshify C case and the front panel (dust panel + bezel) have been removed. I plan to attach 2 of those A12x25 fans in the front using the NA-SFMA1 adaptors. I just don't get where to screw the fan into the case, or with what kind of screws.
