Hi again.
I'm kind of confused on how to make sure the case I end up buying will work with all the components I get. Do all cases generally fit all motherboards? Is there a way to make sure?
I'm also curious about build quality. I've heard the term thrown around before and assume it refers to how well the parts are combined as well as the quality of each individual part? Is this correct?
And finally, is there a preferred sequence for assembling the computer? Like, would you first insert the CPU in place in the motherboard, then attach the CPU fan, then insert the ram, and then the video card, etc etc.
Is there a certain sequence that's best.. or do people do it their own different ways?
How shall I plan to have the best design? I know the video card should have some empty space around it, because it can get hot.. and that you should plan on accounting for the airflow through the chassis.
The last thing I want to do is spend money and buy a bunch of computer parts, and then somehow screw up the build quality.
When I finalize my decision for all of the components, is there a way to plan a head for where each of them should go?
Thanks a bunch!
Thanks a bunch!
