Right, first of all these are my computer specs: (Question below PC specs)
AMD FX-8350 4GHz Socket AM3+ 8MB Cache Retail Boxed Processor
Carbide Series SPEC-01 BLUE LED Mid Tower Gaming Case
Corsair AF120 LED Blue Quiet Edition High Airflow 120mm Fan
Asus M5A78L-M/USB3 Socket AM3+ 8 Channel HD Audio mATX Motherboard
Corsair CSM 650W Semi Modular 80+ Gold Power Supply
WD 1TB Blue Desktop Drive 3.5" SATA-III 7200RPM 64MB
ASUS DRW-24F1ST Internal DVD±ReWriter 24X - OEM
Corsair 4GB DDR3 1600mhz Vengeance Memory Module CL9 1.5V Non-ECC Unbuffered X 2
Using Cooler Master Hyper 212 EVO CPU Fan Cooler
Windows 8.1 64 bit
Now heres my question: How can I change my CPU fan speed in my computers bios? I've read loads of articles on mine but my bios is nothing like any of the articles nor does it have any of the options. I have screenshot each bios window for you to see to help your answer in telling me how to change my speeds. I've tried speedfan and loads of other programs but none of them have worked. Basically I've just upgraded to the Cooler Master Hyper 212 EVO CPU fan from the default amd fan. The default AMD fan would be quiet when idle a bit louder when playing small games however very loud when playing big games such as BF4 obviously from where it was having to work harder to cool. However since the upgrade my cooler master has stayed at the same speed (the lowest speed setting and its silent) no matter what program or game I have open. The issue here is when I play battlefield 4 my CPU goes over the recommended safe 61 degrees to about 70. I want to have the CPU fan work faster - I dont care how fast - as long as it keeps my cpu below 61 degrees when on battlefield. I don't get why it isin't auto adjusting like the default stock fan ive not changed any settings....
Heres the screenshots of the tabs in myBIOS
EXIT
BOOT
CPU CONFIGURATION
POWER
TOOLS
ADVANCED
I will really really appreciate any answers and thank you for reading this - if your still with me!
Many thanks
Jamie
Windows 8.1 64 bit
EXIT
BOOT
CPU CONFIGURATION
POWER
TOOLS
ADVANCED
Many thanks
Jamie
