Hello, I've seen many people talking about how their fan has trouble with keeping cool on their graphics card, yet mine is quite the opposite. I recently bought a graphics card and the fan only runs at one speed (Speedfan and other programs do not even recognize the RPM of the fan). It has a two pin/wire connector for the fan, meaning it only controls the voltage. It is not able to control the fan because it doesn't have three or four pins. Right now the fan is around three times louder than my CPU fan, which I find rather comical. The fan idles on 25C and is 32C while playing Skyrim and other games. I have considered actually unplugging the fan to see if it is able to operate at a moderate temperature without it, but I'd rather not for obvious reasons. 32C seems fine to me, I don't think the fan needs to be running at the speed that it is.
Is there a way for me to modify it through the bios, programs, etc to be able to control it or set the normal speed to be lower? I'd rather avoid decreasing the voltage because I'm not sure if that will cause any damage to it. Is there a way to modify the BIOS on the card to indicate a lower default RPM? It operates at this speed steadily, which isn't too bad since it's the only thing I actually hear...
I've tried programs such as the Nvidia Control Panel, MSI Afterburner, and the aforementioned speed fan to try and set the speed lower.
I'm thinking the only way to do this safely would be to modify the bios, if possible, to have the fan run at a slower RPM right when the computer boots up?
