Hi,
I need to change the original power supply of an HP Z240 workstation against a more powerful standard ATX power supply.
I understand that we need to use an adapter for the motherboard connectors. There are some featuring the necessary connectors, but none of them states compatibility with a Z240. The closest I could find are adapters said to be working with HP Z220 and Z230. But none for the Z240.
https://www.amazon.com/motherboard-6-Pin-Power-Supply-adapter/dp/B01MT5DSXG/ref=sr_1_1?ie=UTF8&qid=1512730552&sr=8-1&keywords=psu+adapter+24+pin+to+6
Does anyone have successfully changed the original power supply of a HP Z240 against a Non-HP third party PSU? I'd appreciate any help regarding this challenge and I want to point out that this is going to be the last HP workstation as long as they use such non-standard/weired components.
best regards,
Bernhard
best regards,
Bernhard
