How to check fan RPM connected to PSU ?
ajinkys
118
Hi,
Can someone tell me how to check the RPM of the cabinet fans directly connected to PSU due to shortage of ports on the motherboard ?
Also, is there any way to change to RPM ? they are not PWM ones.
If they are plugged directly into the PSU you can't read the RPM's, but they will be running at max speed. You would need a fan with a dial or switch to adjust fan speeds for fans connected right to the power supply.
Or you could get a fan controller, and plug the fans into that or, into your motherboard.
