how to check mobo temperature
rafin2000
40
Is there any viable software to check mobo temperature? i use HWmonitor but its shows my mainboard temperature is 117 degrees always. i went to bios too, but they only show the cpu temperature. need help guys.:/
btw my mobo is h81m-E
and all other core temperature of the processor is under 40 when idle. maximum temperature of cpu was 64 degrees.
thanks
You can check your motherboard temperature in BIOS
Reboot your PC
During startup process press the "Delete" or "F1" key to enter the BIOS setup,
In BIOS check for "PC Health" or "Monitor" keywords, It may vary depending on your motherboard manufacturer
Motherboard temp will be displayed in this page.
or
Try using third party applications like HWmonitor or Speedfan which work inside windows and provide you real-time info about your PC
