How to clean my laser mouse sensor from dust.
FiNiTe
Commendable
Aug 8, 2016
How to clean my R.A.T TE mouse sensor.
My table gets very dusty, and the sensors are deep in some cave-like hole and have no plastic to stop dust getting in. This causes it to randomly freeze for a second or two on one axis
Inside I can see two tiny dome-shaped objects, one a-bit behind, the other a-bit to the right of the center of the opening, probably different movement axes which seem to be transparent, the opening is like 2-3mm across, so I can't reach in anything to clean it, should I try vacuuming it? Can I rip anything out?
Any chance of it getting dust somewhere else where it shouldn't be though? Also I don't think my parent have any, and I'm in a rural area and I don't feel like annoying my parent even more, so do you think a vacuum can damage anything?
Here is a pic btw: http://i.imgur.com/smHHVwg.jpg
