Question How to connect 6-pin fans to the motherboard?
Aug 31, 2022
I have 6 6-pin fans in my build that connect through an rgb controller but the controller only has cables for the rgb header on the motherboard and the cable to power the rgb
It doesn't have any cable that could connect to the motherboard.
Is there an adapter that helps with this?
Apr 19, 2023
53
I have a darkFlash rgb fan controller that sounds similar. There is an rgb connect to the motherboard, but no fan connect, and 6 pin rgb fans.
In my case the fan speed can only be controlled using a remote control supplied with the fan controller. There is no option to change the fan speed from the motherboard.
It may be the same in your case.
