[SOLVED] How to connect AMD Wraith Max cooler to get RGB ?
Dec 22, 2018
Hi, i recently purchased a Wraith Max cooler from AMD.
My motherboard is a ASUS TUF B450 PLUS GAMING wich is compatible with ASUS AURA to control RGB stuff ( and the Wraith Max is supposed to be compatible with aura, at least it's written on the box )
I have plugged the fan on the CPU_FAN on my motherboard but nothing show up in ASUS AURA software except my motherboard itself.
What did i do wrong ?
ps : sorry for my poor english, i'm french
Components like the graphics card and DDR4 RAM have the RGB controlled within the motherboard slot. Fans are different they would need to be plugged into a dedicated RGB controller or plugged into a motherboard RGB header.
A regular fan header will power a fan LED, but it will not be synchronized to the Aura software.
hmmm that's what i thought, i have a RBG header connector on my MB but i tried to connect but the fan Fan just wont work.
