First time build, total n00b. Everything was easier than I thought, even though it´s a simple build:
In addition to the motherboard I installed:
i5-6500 processor
2TB Seagate HDD
1x8GB DDR4 memory
Seasonic S12II 520W PSU
will be adding Samsung EVO 850 250GB SSD
All placed in a Cooler Master N200 case with front and back 120mm XtraFlo fans
Each fan has 4 pin connectors - one male, one female. I can connect them to the PSU using the male part of the connector from the fan to connect to the female part of the ´Peripheral 4P' cable from the PSU.
I´m not seeing any place on the motherboard to connect even one of the two fans. Am I missing something? Do I just need to get a fan controller where I can connect at minimum the two fans that came with the case. Any recomendations for something basic that´ll get the job done. I don´t think the system will run that hot, but it´s my first build (and PC) coming over from a MacBook. I live in a permanent spring, high desert climate that rarely gets over 70F/20C degrees.
Haven´t powered it on yet. I´ve read the motherboard won´t boot unless a monitor is attached and I´m still waiting for that to arrive. Will have the family friend computer expert give everything a once over and help me set up Windows, but so far everything has been easier than I thought. Much thanks to the this forum for helping me out along the way.
i5-6500 processor
2TB Seagate HDD
1x8GB DDR4 memory
