Question how to Connect dual monitors to my Thin Client
Jan 31, 2020
I have 2 of the same monitors. I need to connect them to a thin client. The monitors only have a VGA and a HDMI on the back to connect them with. My thin Client has 1 display port, 4 USB and a
DVI. What is the best splitter I can use without having to download any new drivers? Currantly they are working but one is plugged in by display port(thin Client) to HDMI(monitor) and the other is DVI(thin client) to VGA(monitor). Plugged in this way, the resolution and Refresh rate are not matching. And the closest I can get is 1024 and it is WAY TOO BIG!! Help!
"If the source DisplayPort output doesn’t support DP 1.2, the MST function is disabled and becomes a Splitter, mirroring your video source across all displays"
Does your Thin support DP 1.2?
Unlikely.
I have no idea! lol My guess probably not! Since it is a work computer. We cannot download any drivers either onto them.
