Question How to connect Gigabyte Maple Ridge Thunderbolt 4 to PC power supply ?
deeptrance8
13
Hello,
I'm asking for help. I have a Gigabyte https://www.gigabyte.pl/products/page/mb/GC-MAPLE-RIDGE-rev-10/kf
I want to connect to ENDORFY Vero L5 600W PSU with connectors:
CPU 4+4 (8) pin - 1 pc.
EPS12V 20+4 (24) pin - 1 pc.
PCI-E 2.0 6+2 (8) pin - 2 pcs.
MOLEX 4-pin - 1 pc.SATA - 5 pcs.
It turns out that I have free PCI-E 2.0 6+2 (8) pin male connector from PSU
Is there an 8 pin to 2x6 pin adapter or something like that and will it work?
https://endorfy.com/wp-content/uploads/2023/10/EY7A005-wiring_2.svg
Thumbrule with PSU's and their connectors in a build, if you don't have the necessary connectors for your devices you either have;
a| the wrong PSU for the job
or
b| the wrong components for our build.
You can look for adapters, since they're available a dime a dozen off of the www but you'll also find out that fires can and will happen when adapters are brought into the equation. IMHO, you should swap the PSU out to something that has a couple(more than 2). How old is the unit and what has it been powering throughout it's tenure?
Moved thread from Components section to Power Supplies section.
I found ASUS PCIe 3.0 x4 2x Thunderbolt 4 ThunderboltEX 4 90MC09P0M0EAY0 only here will need to use 8 pin to 6 pin adapter and not 8 pin to 2x6 pin as in the Gigabyte maple ridge card.
Please list all components.
Very low end PSU. What's the reason you bought this unit?
Case:
ENDORFY Arx 500 ARGB Case
Motherboard:
GIGABYTE Z790 D AX Motherboard
Processor:
Intel Core i5-14500 Processor
Graphics Card:
INNO3D GeForce RTX 4060 Twin X2 8GB DLSS 3 GDDR6 Graphics Card
RAM:
ADATA XPG Lancer Blade RGB 32GB (2x16GB) 6400MHz RAM
PSU:
ENDORFY Vero L5 600W Power Supply
CPU Cooling:
ENDORFY Spartan 5 Max ARGB CPU Cooler
Case Cooling:
ENDORFY Stratus 140 ARGB Fan
