How to connect home cinema?
bugmenotplz
22
Hi im looking to buy a home cinema system for a very cheap average tv, this tv has 2 hdmi in ports and no hdmi outputs.This Is the tv http://www.tesco.com/direct/technika-24e21b-full-hd-slim-24-inch-led-tv-with-freeview/498-8786.prd?gclid=CKfJusKBic0CFYIW0wod83AIQA&gclsrc=aw.ds#product-details-container
If i buy a home cinema with a hdmi in and a hdmi out port, could i connect the out to the in on my tv and then connect a standalone freeview box to the in on the home cinema, would this work? So anything i connect to the input of the home cinema will show up on my tv screen and the sound will play through the home cinema surround sound speakers, this is the home cinema im looking at http://www.currys.co.uk/gbuk/tv-and-home-entertainment/dvd-blu-ray-and-home-cinema/home-cinema-systems-and-sound-bars/sony-bdvn7200wb-cek-5-1-smart-3d-blu-ray-home-cinema-system-10008669-pdt.html
I just dont want to waste money if i cant get this to work, any help? Thanks
Pretty much - HDMI carries audio and video, so you tend to have lots of things plugged into your cinema amp, with one output to the TV.
One thing to look for is HDMI pass-through - basically it allows the signal to go through even when the amp is turned off, say for example when you don't need lots of speakers and leave the sound going to the tv because your mrs is asleep in the room above...
