Hello
I'm having a real hard time figuring out the fan system on my case and will appreciate some guidance.
Disclaimer!!! I have very little knowledge connector types, port types, ect..and will try to explain what's going on inside my case as well as I can.
I have an antec GX505 steel window case, and I can't get the 3 fans that come with the case to work. From each of those fans is a cable with 3 holes at it's end.
I have an asus h-270 pro mobo with 4 fan ports:
cpu_fan - the cpu fan is already connected to it and working.
cha1_fan
cha2_fan
aio_pump
In addition, I have a switch on top of my case that can be set to HI, STOP or LOW. The visibility of things connected to this switch is very limited, but it looks like there are a bunch of cables that are connected to it:
1. A cable that has 4 rather large silver pins (Molex?) and can connect to the mobo once I use ANOTHER cable that has 4 rather large holes on one end and a 4 pin slot head on the other end to connect to one of the mobo fan ports.
2. A cable that has 3 connection points on it (REAR FAN, TOP FAN, TOP FAN) where each of the cables coming out of the fans can connect to. Each such point seems to have 2 pins on it.
How am I supposed to connect the fans? Each fan directly to a different port? Or, as I am given to understand, I can connect all 3 fans to the cable described above, connect it's other end (using the additional cable) to the mobo and so all 3 fans should work on the same port (kind of like a net of fans with a single connection point, is this correct?). If both are possible, what is the difference between the 2 methods and what should I do in the BIOS program regarding the fans so that all works well?
I have tried connecting all fans individualy to the 3 ports and they all work, but I couldn't get any of them to work when trying to connect them all to the same port.
Thanks a lot!!!!
cha1_fan
cha2_fan
aio_pump
Thanks a lot!!!!
