U Utkarsh_20 Commendable Apr 16, 2016 1 0 1,510 Apr 16, 2016 #1 how to connect my pc(which doesn't have wifi function) to my home broadband wifi using my nexus4 phone as a medium of connection between them without using my phone data??
Solution Phillip Corcoran Apr 16, 2016 There's an easier way which doesn't involve your phone. Buy a wireless adapter for your PC, either an external USB one or a wireless card which fits in to one of your PC's PCI or PCIe slots as appropriate. You can then connect your PC wirelessly to your wireless router just same as you do with your phone.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,102 912 120,140 Apr 16, 2016 Solution #2 There's an easier way which doesn't involve your phone. Buy a wireless adapter for your PC, either an external USB one or a wireless card which fits in to one of your PC's PCI or PCIe slots as appropriate. You can then connect your PC wirelessly to your wireless router just same as you do with your phone. Upvote 0 Downvote Solution
T3CHN0RRI5 Reputable Apr 21, 2014 44 0 4,560 May 16, 2016 #3 There's a technique called USB Tethering Check that out =D Thank me later =) Upvote 0 Downvote
